Clutch Installation help
Old Apr 11, 2005 | 01:24 PM
SR-71 SS's Avatar
Default Clutch Installation help
I am about to install an Centerforce dual friction clutch in my 98 camaro. Centerforce says to also intall a new slave cylinder and throwout bearing, and for higher milage cars a master cylinder as well. What model year slave and T/O bearing should I get, and should I replace the Master and if so with what model year? Thanks
Old Apr 13, 2005 | 10:03 AM
JRracing's Avatar
I think you need to buy the slave & master for a 01-02, thats what I did, works fine!!
Old Apr 14, 2005 | 12:44 AM
rainman's Avatar
My guess would be to replace everything with a 98 model year, I would think.
As far as the master cylinder, how many miles do you have on the car.
Old Apr 14, 2005 | 03:09 AM
jd13's Avatar
Slave was updated in '01. It's a good upgrade to get. I believe GM lists it as a direct replacement anyways, if not, it's easy to find. I wouldn't worry about the master a whole lot unless you plan on some serious power.
