Slave Cylinder Problems
Old Apr 12, 2005 | 10:35 AM
2000Hawk's Avatar
Default Slave Cylinder Problems
currently my car has this issue where if i take it off the line right when i hit the clutch and shift to 2nd the clutch pedal stays stuck to the floor. and at times when i go to throw it into 3rd it will grind. a mechanic told me its probably my slave cylinder. i was wondering when i do go get it changed if thats the problem are their any other things on the transmission that i should get changed? i was trying to save my money so i can get a Spec 3 clutch installed but just wondering if theres anything else? thanks
Old Apr 12, 2005 | 08:15 PM
CW00BlackTA's Avatar
Since you have to pull the trans to fix the slave, I'd go ahead and do the clutch at the same time. A new clutch, pressure plate, flywheel (or resurfaced one), pilot bearing and a new slave (upgraded 2001 or newer version) should cure your troubles. That presumes your grinding going into 3rd is related to the pedal sticking to the floor. The Spec 3 kits come with pilot and throwout bearings. I'd recommend the Spec 3F too if you're going with Spec (see my post today).
Old Apr 12, 2005 | 08:50 PM
6spdpewterZ's Avatar
https://ls1tech.com/forums/manual-transmission/5786-m6-guys-mushy-pedal-after-run.html
Old Apr 12, 2005 | 10:14 PM
JRracing's Avatar
Mine was the same way after about 8 or 9 nights at the track. I got a spec 3, New billet steel flywheel , master & slave. Cost me about 850 in parts & a transmission buddy put it in for 200. no worries now, But after 1 yr now, the peddle has felt funny once or twice?????
Old Apr 13, 2005 | 01:14 PM
2000Hawk's Avatar
thanks for the write up guys.
