Shift Selector Assembly pics?
Old Apr 17, 2005 | 09:09 PM
SScam68's Avatar
Default Shift Selector Assembly pics?
Does anybody have any pics of the shift selector assembly the way its suppose to be setup?
I am finally putting the transmission back together but not to sure if the shift selector is setup correctly. I have the case on with all the gears in place etc and went through the gears. I can hit all of them but want to make sure that its setup correctly before I drop it in.
Thanks!
Frank
Old Apr 18, 2005 | 06:49 PM
SScam68's Avatar
to the top!
Old Apr 18, 2005 | 10:36 PM
SScam68's Avatar
camaroholic? Calhoon?
I guess I can post up pics of the way I have it setup and can you confirm?
Old Apr 19, 2005 | 10:02 AM
1madss's Avatar
That would be good. I just don't have any pics of the assembled shift rails.
Old Apr 24, 2005 | 12:37 AM
SScam68's Avatar
1madss
Here are the pics.
So basically the shift selector and plate interlock align with the slots in the 3-4 and 1-2 shift links and the 5-6 and reverse shift rail levers.
With the case on, but not bolted, I ran through the gears and I was able to hit all of them no problem. Just trying to confirm.
Thanks for any help.
Frank
Attached Thumbnails Shift Selector Assembly pics?-p0001236.jpg   Shift Selector Assembly pics?-p0001238.jpg
Old Apr 24, 2005 | 10:20 AM
1madss's Avatar
That looks good. When you put the guide pins in the case the shift assembly will be held into place.
Old Apr 24, 2005 | 02:54 PM
SScam68's Avatar
Thats what I had figured.
I started to make sense of how the links relate to the gears and their engagement.
Again, thanks for your help.
Frank
Old Apr 25, 2005 | 02:08 PM
calhoon's Avatar
Sorry been out of town. You have them right- it cant really go together wrong( easily that is) You can down load the entire manual ( PDF) from the TTC site for free.
Old Apr 25, 2005 | 08:50 PM
SScam68's Avatar
Thanks Calhoon.
I had the manual but really didn't find clear pics/diagrams.
What fluid would you recommend? I replaced all the blocker rings with CF rings. I asked the shop that I bought the parts from what gear fluid to use and they recommended 50% Mobil 1 30W and 50% ATF. Any thoughts?
Old Apr 26, 2005 | 06:17 AM
calhoon's Avatar
If you're talking about a 30w engine oil / ATF mix get a new shop because they are fools. If you must have a synthetic use a Mobil 1 ATF but a good quality non-synthetic DexIII spec ATF oil will work fine( save some $)
I hope you also replaced the 3/4 fork with the iron part. If you still want pics. Email me.
Old Apr 26, 2005 | 08:48 AM
SScam68's Avatar
The steel 3-4 was at the top of the list. When i took the pick I was waiting for it to arrive and just mocking all the parts up because for the life of me, at the time, I couldn't remember how the links were setup.
I understood 30W transmission oil and have ran across 30W tranny oil, just not Mobil 1 syn. . I am having a hard time finding Mobil 1 transmission fluid period. I am using non-syn. Dex III ATF to clean and lube the parts.
The wife and I will be assembling it throughout the week and hopefully install it this weekend.
Old Apr 27, 2005 | 10:58 AM
SScam68's Avatar
The guide pins were a bit of a PITA to get aligned but got it nailed after a couple of tries.
Its jammed up in 4th, tearing it apart tonight to see whats wrong.
Old Apr 30, 2011 | 07:29 PM
ls6_rx7's Avatar
Just worndering if you found your issue. I'm trying to get my selector installed right and having a few issues
