Haven't seen this post before
Old Apr 22, 2005 | 02:15 PM
ScoonyMan's Avatar
Question Haven't seen this post before
ALL,
Starting on Wednesday I had a weird noise coming form under the car. It sounded like something was loose and knocking up against my drive shaft or the flywheel. I began to think what in the hell could be loose and knocking up against either the flywheel or the drive shaft. It was very weird. When I was stopping fast or braking during a left turn I would here a metallic knocking. However, the car was running strong. So it couldn't be a loose drive shaft bolt, busted pilot bearing or ball bearings. What in the hell could it be.
Yesterday coming home from work exiting off of the Autobahn, the noise came back and i saw and object fly up from under the car. I just knew I screwed something up, but like I said before, the car was running fine, just thought that something was loose and knocking up against the drive shaft. The TA is my only car and I have to get to work. You can see me now praying that I didn't screw up my alum. dive shaft.
I stopped and went back to find an egg sized piece of metal laying on the ground. It was grayish and had nicks in it. My thoughts is the Bell housing. But how in the Hell did I crack my bell housing?
Today I was finally able to get to the craft shop and look up under the car. I was right. The piece of metal I found was from the bell housing. On the driver's side, there is a piece of metal approx. the size of an egg missing and a small hole on the passenger side behind the starter.
How in the hell did this happen.
Thoughts? Well I have a stage 1 centerforce clutch with McLeod adjustable clutch master cylinder and drill mod. Neither Centerforce or McLeod mentioned anything about aftermarket bell housing needed. Is there a way to over adjust with the McLeod?
Thru the hole in the bell housing, I can see small nicks on the pressure plate. There it is my assumption that the pressure plate is pushing up against the bell housing which caused the crack and later break and hole in the housing.
Where do I go from here? It that assumption right and what did I do wrong? Do I need and aftermarket bell housing with more room or do I need to adjust the slave?
Does anyone know the part number for the bell housing so I can order one thru GMdirectparts.com. I'm in Germany so I can't just go to the dealer. Should I get a better bell housing?
Please give advice and counsel.
Old Apr 22, 2005 | 04:53 PM
kenp's Avatar
Looks like the part # is 12453263, $210.33 plus shipping. It's listed under transmission and they designate it the clutch housing.
Old Apr 23, 2005 | 12:53 AM
ScoonyMan's Avatar
Thanks Kenp!
Anyone have any suggestions on what to do with the over adjustment on the clutch? I don't want to replace the bell housing and have it crack and break again!
Old Apr 23, 2005 | 09:21 PM
TRex's Avatar
While you are at it, I would put in the new scattersheild available for our cars.
Old Apr 23, 2005 | 09:48 PM
ace68's Avatar
Yes Mcloud I think that's how you spell it, They have a new housing it's steel I will be getting one for my older F body.
