slave just went out
Old Apr 25, 2005 | 10:24 PM
shanev8's Avatar
Default slave just went out
i just installed a fidanza aluminum flywheel a spec stage three and new upgraded gm hydrolics,
i was at about 110 miles of ware in period for the clutch when i put the clutch in for a stop sign and noticed it didnt want to go in neutral then i notice the clutch is stuck to the floor, anyways i went back home took my tranny out and noticed fluided was all over the belly housing, and the slave had its greese shooting out. i asked around and people think the drill mod might have been the reason why.
any one have any suggestions as to why this would happen to me for the second time in 2 weeks, it can save me money if u have any suggestions thanks
Old Apr 26, 2005 | 09:11 PM
P Mack's Avatar
When you pulled your tranny did you have to pry on the bellhousing a lot cause the dowels were seized up?
Old Apr 26, 2005 | 09:37 PM
shanev8's Avatar
no everything just came out fine, i ended up buying another slave and master today, now i cant get the pedal hard, i think after 20 times of bleeding it would work now but it doesnt, hmmm anyone?
