Help, Clutch disengagement problems
I just recently began swapping from a 4l60e to a M6 here the last week. I just buttoned everything up. The kit I purchased came with what I think was a used spec stage 1 clutch and pressure plate. I installed a new slave cylinder and master cylinder and bled the system completely. Now for my problem.. The pedal feels pretty good but when I start the car and go to put it in gear.. NOTHING. It won't go into gear, feels like the clutch isn't disengaging at all. I know a friend who installed a spec stage 3 and he had to shim his.. There was no shim in my kit.. Is it maybe that the 1 and 2 require shims also?? Please help guys, I need my car fixed ASAP
Thanks!
