6-5th downshift
-Kyle
98Z28_SS
5th and 6th gear are pretty much like the first 4 ( has a shift fork, synchro assembley, and individual speed gears, but the driven gears are one cluster on the mainshaft) except they are in the extension housing. It could be a number of things. Worn shift fork pads ( the shift fork it self is steel) , broken synchro keys, engagement teeth worn on 5th gear, synchro hub worn. Hard to tell without more info or taking a look in the extension housing. The plus about 5th-6th are that you would most likely not have to tear into the main housing.
