flywheel
Old May 2, 2005 | 08:01 PM
yellowbird1232's Avatar
Tech Fanatic
Default flywheel
Which is better steel or aluminium (m6)? What is the advantage of one over the other?
Old May 2, 2005 | 08:30 PM
TJ's Avatar
TJ
if you have transbrake or clutch dumps... the aluminum will go out on a hi HP car. you can buy an aftermarket aluminum that will hold. i prefer steel if you have huge power and a heavy car.
bolt on or a cam car, the stock aluminum should be fine.
Old May 2, 2005 | 09:32 PM
Manoso's Avatar
the lighter aluminum will rev more freely but requires a little more throttle when launching, where the steel will launch the car with ease but a little less revvy. this is because of the weight of each and the rotating mass.
Old May 2, 2005 | 10:33 PM
jaredwayt's Avatar
the lighter the flywheel, the quicker it will rev, hince there have been hp gains from 5-10 hp with a lightweight flywheel, but i would just reccomend resurfacing your factory unit if its in decent shape, it's very very cheaper, and i know people running spec stg-5 clutches with stock flywheel pulling the wheels up, so its up to you...
Old May 2, 2005 | 10:40 PM
TJ's Avatar
TJ
i dunno why i thought driveshaft.
forgive me.
Old May 3, 2005 | 12:10 PM
Tech Fanatic
I just purchased a mcleod street twin with an aluminium flywheel. I was just wondering what the advantages were. i am pretty sure that there will be a difference in shifting due less mass in the flywheel.
Old May 3, 2005 | 01:33 PM
waltsfastz's Avatar
I bought a SLP billet steel flywheel. Main reason is I had to have one balanced and I had safety in mind
