Master & Slave Cylinders
Old May 8, 2005 | 05:56 PM
HellRaiser's Avatar
Default Master & Slave Cylinders
Soon I will put in my spec 4f into my 99ta and read here that you should do the master & slave while your at it. For what reason's should I do this? I mean if it's not broke why fix it... Has anyone here not upgrade thier stuff and not have any problems. What problem could I have?
Old May 8, 2005 | 06:16 PM
AW794's Avatar
They upgraded the slave cylinder in 01 and 02. I also am doing a clutch swap on my 99 TA. I think its a good idea to replace it while its tore down. As for the master? Im not sure. Maybe someone else knows.
Old May 8, 2005 | 06:20 PM
Onyx Z's Avatar
The master was upgraded in 2001 as well. Replace them both and be done with it.
