Clutch Safety Switch
Old May 9, 2005 | 01:00 PM
BlutVonSchwachen's Avatar
Default Clutch Safety Switch
The other turned I found that I can turn over the motor without having the clutch in, is this causing any harm as long as I keep it out of gear when turning it over?
Old May 9, 2005 | 01:28 PM
991LE's Avatar
It shouldn't hurt anything, but I would get it fixed. You might have some trouble if you push in the clutch while the cruise is engaged.
Old May 9, 2005 | 02:03 PM
kenp's Avatar
I'd fix it. It's simply a very serious safety issue.
