do you need a adj master with....
Old May 10, 2005 | 10:48 PM
unstopablez28's Avatar
Default do you need a adj master with....
a spec stage 3 clutch install?? i am about to install my spec stage 3 clutch and was wondering if i need to get a adj master for install?? also are there any special shims i need. saw another post and wasn't sure if it applied to the spec clutch. thanks
Old May 10, 2005 | 11:55 PM
Krab's Avatar
No, an adjustable master cylinder is not needed. If I'm not mistaken, spec recommends you go with a non-adjustable master (stocker) for their clutches. There should be a shim that will come with your clutch that goes between the slave cylinder and the tranny. I think the thickness is .055".
Old May 11, 2005 | 12:38 AM
ok i got it thanks. also how do you know if i have the new 3i clutch from spec??
Old May 11, 2005 | 07:15 AM
Michael Ozorowsky's Avatar
what is a 3i clutch?
Old May 11, 2005 | 03:24 PM
i though that spec changed their clutches to dual compound or something?
