McLeod Master Install Question
Old May 15, 2005 | 08:31 PM
Johnny5's Avatar
Default McLeod Master Install Question
When you installed the master did you have a "U" bolt or two bolts to install through the firewall? Mine came with two bolts and it seems a "U" would be a much easier application since there is about no way to get a wrench down in there.
If it does use a "U" bolt where could I get a new one for that install?
Old May 15, 2005 | 08:47 PM
991LE's Avatar
I have two of em. In one the holes in the master are threaded. This was the easiest to install. In the other the holes weren't threaded and I had to put nuts on the bolts to install it, it was a PITA. I ended up tack welding the nuts on the older master and now I just thread the bolts in like I do the newer one, much easier.
Old May 16, 2005 | 05:04 PM
Johnny5's Avatar
that is a good idea.. so you put the bolts through the cabin and into the engin bay then I assume.
Old May 16, 2005 | 11:24 PM
991LE's Avatar
Thats right.
