Spec stage 3????
Old May 16, 2005 | 10:15 PM
Michael Ozorowsky's Avatar
Default Spec stage 3????
I just bought a used spec 3 off a member here, and am about to install, and hopefully have my car driving in next month. I'm new to manual tranny's so I get to skip over the learning curve, and I have SO MUCH to learn about manuals. I'm converting A4 to M6 btw. So anyways, if my clutch burns out, can it be rebuilt by trans shop or something or am I S-O-L and have to buy a new clutch if something goes wrong?
For the record nothing is wrong as of right now, just curious.
Old May 23, 2005 | 08:30 PM
ttt guys?
Old May 23, 2005 | 09:17 PM
C_B64's Avatar
If your clutch gets worn out... You have to buy a new one......
Old May 23, 2005 | 09:49 PM
DAMN!!!! So that's like $400+ a POP!!!!
Old May 23, 2005 | 09:55 PM
Vertigo's Avatar
Not really you will need a new clutch disc (pad) not the whole kit again (Pressure Plate, Flywheel, & disc)....just the disc, Unless you want to up/down grade...
Old May 24, 2005 | 07:25 AM
How would you get just a new clutch disk? Call spec?
2002z28's Avatar
i think spec can also just put new friction material on your burnt clutch. i may be wrong.
justin
Old May 24, 2005 | 07:51 AM
Vertigo's Avatar
justin
Yes that is correct..you can get it re-pucked. Re-pucking for a Spec 3 is $79 via Spec.
Old May 24, 2005 | 09:17 AM
SS01RED's Avatar
That's pretty reasonable...
Old May 24, 2005 | 03:17 PM
VERY reasonable. Thanks guys.
