Installing Adjustable Master (Mcleod) - Help
Old May 25, 2005 | 11:44 PM
Johnny5's Avatar
Default Installing Adjustable Master (Mcleod) - Help
The bolts that came with the kit (2 bolts / 2 nylon lock nuts) ended up not fitting correctly and never got the master tightened down right.
I finally tried to fix it tonight and as I thought the lock nuts had actually stripped the bolts and one actually sheared off.
IT IS A MAJOR PITA to get a hand and wrench back there to attempt this install. Can I use a "U" bolt like what the stock clutch it held in with to secure the master so I don't have to get a wrench in there?
Anyone know what size I'd need or part number?
