My M6 Synchronizers
Anyways, I have three questions. The first is ... anyone have a reccomendation for a reliable shop to replace my synchronizers in the Houston or Austin area at a reasonable rate? I'm probably going to avoid dealerships at this time.
Second question is a two part question ... how difficult is it to do the job yourself and is there a T56 service manual readily available showing how to do it? I'm relatively mechanically inclinded and don't mind doing the work myself as long as I feel I have a handle on how to do it.
Third question is ... are there any aftermarket synchronizers of better quality available for the T56 that will last a bit longer?
Thanks for the help ... Jared H.
I do not think there are any aftermarket syncros out yet...the only aftermarket thing that was released lately was the steel shift fork... <img src="gr_stretch.gif" border="0">
Good Luck
262-889-4346 ask for Norm
Racer88 ... I may do that if I can't find something locally ... thx for the info on the viper sychros ... why are they better?
Anybody else? TIA JHH
Good luck on your tranny, and keep in mind that guy Norm at Westech is nice enough to even sell you the parts and give good information.....
He recommends drilling the slave (drill mod)....I would find out more about that. My boyfriend did the drill mod and has had no problems w/ his re-built tranny so far.......LOL
Its going for 700 and the only thing wrong with it is a bent 3-4 shifter fork which which was on TSB report..
Racer88 ... thanks for the info ... I'll probably give him a call and see what the cost would be to upgrade the synchros as well as get the lower first, second, and third gears that the Z06 is getting ... might be cost prohibative ... won't know until I call ... thx again.
No recommendations on local Austin or Houston area shops to do this yet ... anybody?
