Please help determine the problem???
Old May 31, 2005 | 02:39 PM
CRM's Avatar
CRM
Default Please help determine the problem???
Hey as u know i have purch. a ram power grip setup (clutch,adj.master,slave,flywheel,presure plate) and everything was great untill yesturday. My Clutch Pedal takes its time going back up and it is not as grippy as it was before. It does not slip, I donno What Can Cause that Do YOU?
I know the drill mod is for clutch fluid to flow better,but My CLUTCH WAS NOT LIKE THAT BEFORE
What Can Cause IT?
Old May 31, 2005 | 03:59 PM
2000TransAmWS6's Avatar
the first thing that comes to mind is the master cylinder (ie. internal leak)
your best best is to call Ram and ask them.
in the mean time, think about the most simple things that it could possibly be... return spring, fluid (bled properly with DOT3, or contamination), etc.
