Problem Shifting To 2nd
Old Jun 12, 2005 | 04:52 PM
TOS98SS's Avatar
Default Problem Shifting To 2nd
I have an 98 SS camaro and It seems like every time I rev it out it dosent want to go into gear right away It dosent grind it just seems to hold in the neutral position,
Has this happened to anyone , It seems to happen at least half the time i shift at high RPMs
Old Jun 12, 2005 | 05:30 PM
02 BLK WS6's Avatar
My m6 is one stiff sob. When at the track I have to muscle it to power shift. I am affaid that if I keep this up I will most definately send the internals to an early grave. My best guess is to bleed all hydraulics until all fluid that comes out it clear and fresh. Make sure that the lines are protected from engine heat. Mine is hard to get into 1st and likes to pop out of 3rd and 4th with the touch of a finger while p()55y footin around town. I think that it is just normal for these.
