Dumb Hydraulic question...
Old Jun 28, 2005 | 05:54 PM
Michael Ozorowsky's Avatar
Default Dumb Hydraulic question...
Hey guys, please BEAR with me here. I have all hydraulics installed, waiting on bellhousing. If I hookup slave cylinder to master I have some questions. No fluid right now in car. Can I go ahead and turn ignition on (NOT start car just ignition on) and pump the clutch/bleed it and put fluid in? Does car have to be running for clutch pedal/master cyl to start working?
Any negatives to pressing clutch pedal with slave connected, but no transmission in there? Just trying to see what I can get away with doing while waiting on parts. Was going to wait until I put tranny, etc. in there before bleeding hydraulics, but was thinking maybe I can do it now??? ANY info is appreciated.
Old Jun 28, 2005 | 06:11 PM
lsp408's Avatar
car is running or not have nothing to do with the system, you can go ahead hook it up and bleed but make sure get big c- clamp and couple thing wood put on both side of slave. so when you press down the peddle, you won't over extent slave cause seal blown
Old Jun 28, 2005 | 10:53 PM
wrencher's Avatar
wrencher
It doesnt need to be running to bleed. You do need the trans bellhousing & motor assembled b-4 you pump the clutch pedal.
Without them assembled there is nothing keeping the slave from over-extending.
Old Jun 29, 2005 | 10:45 AM
1madss's Avatar
Yep, keep your foot off of the clutch pedal unless there is something to restrict the travel of the slave. Otherwise you will be buying a new slave.
