Little hard to get into first.
Old Jul 1, 2005 | 01:20 AM
goober35's Avatar
Default Little hard to get into first.
Tranny has less than 500miles on it and so does the twin disk. When i stop at a light or sign and try and go into first i have to give it a little exstra unff to get it in. Is this normall.
Old Jul 1, 2005 | 09:24 PM
kenp's Avatar
No that doesn't sound normal. Have you tried the other gears when you are stopped? My guess is that they are also difficult when you are stopped. Sounds like maybe the disc is not fully disengaging. But if when you are sitting still with the engine running you can shift into the other gears smoothly, then I guess it's a problem w/1st.
Old Jul 2, 2005 | 02:19 AM
goober35's Avatar
OK i will keep bleeding.
