reverse?
Old Jul 4, 2005 | 10:11 PM
Michael Ozorowsky's Avatar
Default reverse?
Is everyone's reverse a "little" hard to put into? And no, I don't mean reverse lockout. Just all gears easy to go into, but reverse a little tougher than others. Is this normal?
Old Jul 5, 2005 | 01:59 AM
8-Pack's Avatar
When I get into my car first thing in the morning I usually have to put it in first then reverse, but it goes right in the rest of the day.
Old Jul 5, 2005 | 04:05 AM
Strahley's Avatar
My old 3rd gen's T5 did that, I had to go into a forward gear before I could go into reverse, otherwise it would grind. Even then, it was hard to get it into reverse
My T56 hasn't done that to me yet, but it only has about 30k miles on it. But if I do recall, I beleive reverse has a little bit more "resistance" than the forward gears, but it's not hard to get in
Old Jul 5, 2005 | 09:43 AM
exactly. NO grinding when going into reverse just a little "harder"
Old Jul 5, 2005 | 10:59 AM
calhoon's Avatar
Reverseis synchronized but it has a brass alloy blocker ring ( instead of paper or carbon composite lining) which may explain the higher effort.
Old Jul 5, 2005 | 07:35 PM
So is that normal? I'm PRETTY SURE my clutch disengages all the way, because when I have all 4 wheels on ramps, hold clutch in, tires DO NOT move.
Old Jul 6, 2005 | 09:40 PM
Y2K SS's Avatar
Yes its normal. All the M6's I've seen are like that.
