m6 ?'s
!!! Clutch selection is a bit tricky as there have been some bad experiences but that's not an M6 issue - it's the aftermarket clutches and the installs. That situation is improving with some new and better clutches available.
It runs on Dexron fluid and for maintenance, there isn't a great deal to do. If you want to be safe, have the trans built buy someone like Rockland transmissions when you pull the trans to do a clutch. Other than that, drive and enjoy running it through the gears like I do every chance I get!!!
