Ram Clutch recommendations needed
Old Jul 16, 2005 | 05:01 PM
Gold Phoenix's Avatar
Default Ram Clutch recommendations needed
This is going to be my fifth clutch in this car. I am building a 402/408 iron block for an F1R Procharger system. I have had the 6130, 910, and 908 discs from RAM. The previous setup was nitrous. The 6130 was fusing to the flywheel and pressure plate with the spray. The 910 was ruined by the slave cylinder failing. And I think the organic side of the 908 is wearing out with the slipping of the clutch on launches. I am think of going back to 6130 on the next setup since it didn't chatter as much as the 910. I don't want to use the 908 again since the organic side will wear out faster than the sintered iron side. Now what I would like to know is, will the 6130 disc work better without problems? I know the 910 will hold, but I hated the chatter with it driving around town. Comments? Opinions?
Old Jul 19, 2005 | 01:59 AM
anyone?
