I NEED help BADLY
Then to top that off you where needing a trans overhaul w/ it was grinding into 3/4.
I know it sucks but thats the way it goes. Been there.
These trans's will hold up w/a quality rebuild/upgrade. You also have to insure the hydraulics are working correctly so normal shifting does not cause undue wear.
