Another Textralia installed
Old Jul 30, 2005 | 03:35 AM
LSs1Power's Avatar
Default Another Textralia installed
What a clutch.... I love it. Really soft pedal and almost no chatter. Its grabs like hell. Don't like the high engagement point, but thats most likely due to the Mcleod adj master which is going out as soon as i get a stock one. Can't wait to tune my car so i can take it to the track.
Advice: Don't waste your money on SPEC or anything other clutch. I had two SPEC 3's before and they didnt last 1000 miles each. Good luck everyone
Old Aug 3, 2005 | 09:10 AM
SSnakekiller's Avatar
https://ls1tech.com/forums/showthrea...extralia+pedal
Although now I am wondering if I should put the stocker in bc the Mcleod is getting mushy, it might need a rebuild...
Old Aug 3, 2005 | 05:05 PM
JRracing's Avatar
Mine is doing good also. The peddle release is high also and it's stock 01-02 hydro's but I put a thick shim behind the slave when I put it together. It was'nt like that before with the spec-3. I'm getting ready to do the drill mod tonight. Like a lazey *** I did'nt take it out when the tranny was out. It needs it bad, and a good bleed job again. Man I'm about a pro at bleeding them also.. I've got 3 passes on it and none of the are worth speking about. Other issues, but fixxed now.
