Cts-v M12
Old Aug 2, 2005 | 09:24 PM
Lostpatrolman's Avatar
Default Cts-v M12
What is required to fit the CTS-V T56 in an fbody? Is it as simple as swapping the tailhousing and tailshaft? It is an M12, so it would have better gearing then the MM6. Thanks for any opinions or advise.
Old Aug 3, 2005 | 06:50 AM
calhoon's Avatar
You would be better off swapping a GTO box(same ratios) - swap shifters. The CTS-V is too different at the back and shift linkage you can do it but its spendy.
Old Aug 3, 2005 | 05:14 PM
What all is involved with the gto trans? Is it as simple as swapping tailhousing and tailshaft?
Old Aug 4, 2005 | 07:26 AM
calhoon's Avatar
I think its easire than that- just a shifter swap.
