possible bad hydraulics???
Old Aug 7, 2005 | 08:07 PM
1FST99Z's Avatar
Default possible bad hydraulics???
well I was driving home from work today and noticed that when I tried to downshift I couldnt put it in 3rd or second then I stopped and then I could put it back in first but it was tough. then it got to the point where I couldnt put it in any gear of course then it stalled out. well I managed to start it in gear and limp it home in 1st gear. when the car is off i can run through the gears but when I try to start it I cannot put it in any gear at all with the clutch to the floor. I put a Ram HD clutch, pp, throwout bearing, and I new slave I believe that is what it is. well the part in question sits behind the spring and has the hydraulic line hooked up to it. all that was new. but I left the old master cylinder. please help any info would be greatly appreciated.
thanks in advance
Wesley
Old Aug 10, 2005 | 02:19 PM
1FST99Z's Avatar
anybody????
Old Aug 10, 2005 | 02:55 PM
lilbuddy1587's Avatar
sounds like the clutch isnt fully disengaging/engaging. Could be clutch, could be hydraulics.
