adj. master installed
Old Aug 8, 2005 | 10:03 AM
Vertigo's Avatar
Default adj. master installed
Those of you who have an M6 this is a GREAT mod! This all started when I put my Spec III in about 2months back. After installing the slave cylinder on the transmission I obviously needed to bleed the system. Well long story short the clutch pedal wasn't returning. After giving up on the bleeding I decided to start the car and everything SEEMED fine. Well a few weeks go by and occationaly the transmission would grid when i put it into 1st whereas b4 this never happend.
After taking the master cylinder out I noticed the resivor hose was barely attached. I knew it had to have been sucking air into the system while trying to bleed before. Well after modifying the master to make it adjustable I bleed the system and it was 1,000X better. Now the pedal is SOLID, not spongy and I can adjust it to exactly where I want it!
Old Aug 8, 2005 | 11:45 AM
Onyx Z's Avatar
Is it a RAM or McLeod master?
Old Aug 8, 2005 | 01:54 PM
Vertigo's Avatar
Its the stock master made adjustable by...Me, a dremel, and 2 nuts.
Old Aug 8, 2005 | 02:14 PM
GTObsessor's Avatar
Lol...he said... *2 nuts*
Old Aug 8, 2005 | 08:02 PM
HavATampa's Avatar
heh...nuts. You reckon the master would be just as good after fixing the leak and not making it adjustable?
Old Aug 9, 2005 | 08:19 AM
Vertigo's Avatar
Pressure wise...YES. But then you loose the adjustablility. I feel this was well worth the time it took. Getting 4.10 put in tomorrow...that should be fun!
