Poly Transmission Mount - Tips and Impressions
1. Energy Suspension Poly Mount= Mounted it without Preload Plate and it is awesome!!! Best Mount on Market!!!!
2. 1LE Rubber GM Mount= Very Quiet, Very Solid, Good Overall Mount!!!
3. Prothane Poly Mount= Very Noisy, Unbreakable but breaks everything else it is attached too, I had it on less than 24 hours and cracked my M6 Tailshaft housing in half!!!
I'm going to leave the poly TA mount in there and pull the cover off the axle shortly and see what I can see. Maybe some fresh lube and some magnets will help the situation.
