Weird Clutch ?
please help me out. thanks guys
If you did that, then it should be properly bled.
Is the pedal resting in the 'right spot'? Lightly resting against the switches/stop at the top of the travel? If not, then you'd need to make your master adjustable (or get an adjustable one).
Sounds almost like there's air in the line, tho.
when i was bleeding it, everytime we closed the thing the pedeal would stick to the floor and id have to pull it up.. then it would have pressure agian
