flywheel.
Old Jan 30, 2002 | 11:19 AM
CamSS00's Avatar
Default flywheel.
I have a stock flywheel that I'm putting back in. I got it new from star. Should I take it and have it cut down or is it ok??. I put a polybushing in the trans. If the rubber stopper suppose to be against the body?? Or should I take that plate out so it lowers the trans.
Thanks
Jeremie
Old Feb 12, 2002 | 10:43 AM
WILWAXU's Avatar
Default Re: flywheel.
As a general rule, you should always resurface a flywheel when replacing the clutch.
