A4 to M6 question
I'm assuming it will be mounting the fluid resovior to the firewall??
I have LS1Edit, so I'm capable of flashing a new file into it from an M6
Any info or tips is appreciated!!
How will you flash a new program using LS1Edit? From another car? But then you'll load the other VIN also. Do you have more than a license for Edit?
We can share some info about the swap, if you want..
Stefano
Reprogramming will take no time at all......all I have to do is get on one of the bin file sites and get a program for an 01 M6 camaro
Any info on what part of the......I guess I would say "fabrication" would take the longest??
The only parts I haven't looked at to see if the factory "outlined" it is the hole for the lower shift boot where the shifter comes up through the floor. That's something thats going to need to be a perfect cut because the boot needs to fit nicely in the hole and plus it needs to be centered on the shifter right. There is no hole like that in the trans tunnel (sp?) of an A4 car.
I made some precise measurements from my friends M6 car and placed the carboard down according to those measurements and I have the same exact whole in the same place as OEM.
For me, the the hardest part was the pedals and getting them aligned just right. The resevoir was cake, it's just held in with one bolt or or a factory plastic expanding fastener.
Dan
As long as you change the VIN to match your car then you are fine.
If you're setting a SES Light then you will fail emissions anyways, and with a tuning program you can acutally DELETE the SES codes and make the light go off, making you pass emissions tests.
This is helpful if you have any mods that will throw a code in the computer (egr blockoff, air pump delete, off road y-pipe, and several other things)
But how to change the VIN? I'v never find this function in Edit. And if you retype it it will save the file with the original VIN.
Please explain
this is the only thing that is holding me to do the trans swapThanks - Stefano
With LS1edit, I know you can do it, but not sure of the method. I heard if you have the same year flash with some certain part of the VIN # being the same you can do it.
