Slave bleed valve mod...worth the time.
Old Sep 4, 2005 | 01:54 PM
NassyVette's Avatar
Default Slave bleed valve mod...worth the time.
I tapped the bleed valve hole and installed a standard bleed valve. I then welded it in to ensure a leak proof seal. I was able to bleed the clutch from the ground up, completely dry in 15 minutes. I saw the idea in a thread while I was searching...its definately worth the time it takes to mod it.
Old Sep 4, 2005 | 02:34 PM
OneMeanZ's Avatar
Can you post a link to that thread??
Old Sep 4, 2005 | 03:46 PM
gnx7's Avatar
Would you be able to post a pic of the mod?
Old Sep 4, 2005 | 04:50 PM
WS6WRX's Avatar
good idea!
Old Sep 4, 2005 | 10:55 PM
NassyVette's Avatar
I'll snap a pic in the next couple days when I drop the trans back down to install a shim.
Heres the thread that I got the idea from: https://ls1tech.com/forums/showthrea...ght=mighty+vac
I'll put up pics of it as soon as the shim comes in.
