A4 To M6 Items
Old Sep 7, 2005 | 05:06 AM
Zerokube's Avatar
Default A4 To M6 Items
Can someone post or pm me with all the things i'll need from an A4 To M6.
Thanks.
Old Sep 7, 2005 | 07:14 AM
Griswold's Avatar
for the hydraulics you will need master, slave, pilot bearing, pedals, flywheel, clutch and pressure plate. For the tranny you will need bellhousing, tranny, shifter, torque arm mount and bushing, and cross member. Your a4 torque arm and driveshaft will work. I would also recommend getting new flywheel bolts and pressure plate bolts. Then there are the miscellaneous things like the upper console, shift boot, and electrical connectors for the tranny. You can make the connector for the reverse lights from parts you can buy at pep boys. All the other connectors are the same. I think that is about it.
Old Sep 7, 2005 | 11:09 AM
Steve Burger's Avatar
LS1TECH Sponsor
What parts do you need? I still have some left for a t56 swap. I have the master and clutch.
Old Sep 7, 2005 | 08:06 PM
Zerokube's Avatar
Thanks guys, i need everything.
Old Sep 8, 2005 | 08:46 AM
LS1TECH Sponsor
Let me know if you need the master and/or clutch.
Master is 3 months old and has the McLeod braided line on it. All together this was about 230.00 new
Clutch is a Spec S4F with a brand new in the plastic disk, PP, and Billet FW. Also 2300 miles. This was about 950.00 new.
Make an offer if you would like any or all of this.
