TO bearing always spinning?
Old Oct 23, 2005 | 04:40 PM
tici's Avatar
Default TO bearing always spinning?
Is the throw out bearing always spinning?
I guess yes because the spring between the bearing and the slave cylinder pushes the bearing against the fingers of the prassure plate which rotates with the engine.
I just wonder how this bearing can survive this continous rotation with just the original grease.
Old Oct 23, 2005 | 05:24 PM
wrencher's Avatar
wrencher
Yep always spinning, just under a load when pressure plate is disengaged.
Old Oct 24, 2005 | 12:33 AM
tici's Avatar
Thanks! This was almost obvious... I was just looking at it and was thinkiong how is it possible. It's mounted on a piece of plastic and in front a thin metal sheet
