A4 to M6 swap and reverse lockout
Old Oct 25, 2005 | 05:54 PM
tici's Avatar
Default A4 to M6 swap and reverse lockout
In order to have a functioning reverse lockout solenoid after a A4 -> M6 swap you should either get a manual harness or route a cable from the PCM to the solenoid (wich is a little complicated).
How about using the signal from a stop light? Before shifting in reverse you have to brake so or so. Routing a cable from a stop light should be easier than from the PCM.
Old Oct 26, 2005 | 07:59 AM
tippmann243's Avatar
DING DING....but everyone already does this
Old Oct 26, 2005 | 10:11 AM
tici's Avatar
Ouch... I never saw a post about that so I had to figure out how make it work. At least I know it's not wrong.
Thanks!
