pro 5.0 shifter stops
Opinion
actually a myth): Shift forks in a T56 are bent by overtravel. This myth is what sells shifters with stops - pure marketing bunk.I they were so great why won't the warrant them aganist bending a fork?Fact: What bends a fork is clash shifting- A stop will do nothing to prevent that.Clash shifting is a driver -controlled condition ( no one has come up with a driver stop - except an automatic)
Fact: stops are adjustable and therefore mis adjustable. Mis adjusting stops can cause a fork issue by short shifting.
Do what you ewant but the best thing you can do is crank them out well away fron the shifter and loctite them so they don't come loose. They will do the best when they are ineffective.
Hope this helps
you are doing it right but to me it sounds like you have no choice but to use 3rd and 4th as the stop points since you need to be able to use them. You could just remove them all together as well but hell you got them may as well use them as best you can.
