m6 problem
Old Nov 6, 2005 | 09:31 PM
GA/TA's Avatar
Default m6 problem
Tranny making alot of noise, still shifts fine just lot of noise when shifting and almost sound like the shifter is rattling when crusing. any thoughts on what it could be?
Old Nov 6, 2005 | 10:14 PM
five0killr's Avatar
pull the console, check every bolt, go underneath and do the same, odds are its not an internal trans problem, unless you havnt had fluid in it, or someone did a bad job rebuilding it
Old Nov 6, 2005 | 11:33 PM
SUTTERERMAN85's Avatar
mine is doing the exact same thing. i think i have some bearings taking a dump. its comming apart next weekend and will be rectified hopefully.
Old Nov 9, 2005 | 09:17 AM
GA/TA's Avatar
let me know if you find anything in your so i can try to fix whatever the hell is going on.
