t56 in a 69 camaro
Old Nov 15, 2005 | 09:01 AM
sharp1's Avatar
Default t56 in a 69 camaro
I'm going to use a t56 in a 69 camaro with a LS1 motor. Does the shifter cut out need to be modified? The car is an original 4spd car. What do you use for the clutch set up and how much modifying is needed
Old Nov 22, 2005 | 08:26 PM
sharp1's Avatar
no help out there??? has nobody done this or anythig like it?
Old Nov 22, 2005 | 09:30 PM
Strokinit383's Avatar
Not sure about the hole, id just jack the tranny up there and find out. As for the pedals, you will prob have to use the hydraulics unless someone develops a cable setup for that tranny.
Old Nov 22, 2005 | 09:32 PM
Oh, and you might try posting this in the conversions forum.
