Clutch Match Balancing
Am I missing something here? You are to have the clutch assembly and flywheel assembled and put onto a balancer and checked. Everybody keeps on telling me that they can balance just the flywheel and pressure plate seperatly. I thought they were supposed to be balanced as a unit! Anybody?
Usually you first balance the flywheel alone, then bolt the PP on it and add/remove weight from the PP.
