Exedy Twin Disc Problem
I didn't get any instructions with the clutch and just torqued the pressured plate (35-45-50) like a stock one. The second disc assembly I left assembled the way it was from the previous owner. The high side of the first clutch disc was placed towards the pressure plate. Everything was lined up fine with the alignment tool and the trans went in fine.
Just wondering if anyone had the instructions they could post or if they know anything about torquing the pressure plate or if there is anything special I need to do with the second disc assembly to set it up or any other suggestions. I'm about to pull the trans to take a look at the clutch assembly.
Be easy on me I mostly deal with automatic transmissions and stock style clutches.
I found online that the torque specs on the PP bolts are 48 ft lbs and I went to 50 so I don't see that being an issue.
Anyone have a copy of the instructions they could scan or take a picture of and post up? I have a feeling getting a hold of Exedy may be difficult since they are from the UK I think.
