caliper grinding
Old Mar 2, 2002 | 02:31 PM
bigSS's Avatar
Default caliper grinding
Anyone have any pics of grinding for there Weld wheels? I'm having real trouble getting my Pro-Stars to clear with the spacers. <img src="gr_images/icons/mad.gif" border="0"> Thanks.
Old Mar 2, 2002 | 03:13 PM
Sears's Avatar
!Dial-up Director
Default Re: caliper grinding
http://jsears8.cz28.com/prostars/grinding
Put grease on the inside of the wheel, torque it down, spin a couple of times (wheel not you), remove wheels, grind until no more grease is being left on the caliper.
Justin
Old Mar 2, 2002 | 08:14 PM
SteveD's Avatar
The grease idea works great. Make sure that you drive around and make some tight turns before you say the you are finished. Making the turn off of the 1/4 mile in Baytown is where mine started rubbing again.
Old Mar 4, 2002 | 03:59 PM
WILWAXU's Avatar
Yeah.. I used a red marker on the caliper...
