McCleod Master help
Im trying to install my mcleod adjustable master and the line from the stock reservior is really loose on the nipple of the mcleod master. The instructions say secure with the provided ziptie. It would be possible to get it so it stays on but theres no way that will make an airtight seal. Has anyone else run into this problem? I think maybe they put the wrong size nipple on the master.
Long story short I went to vaccum bleed it and started sucking a bunch of air in through that fitting. I tore the M/C out and used a hose clamp on it (the notched metal bands with the screw you turn). It's been working flawlessly ever since.
