clutch problem...need help?!?
Old Jan 7, 2006 | 08:43 PM
ChaseSS's Avatar
Default clutch problem...need help?!?
while racing a MACH 1 mustang that I killed, my clutch stuck to the floor and I could only push it in about a inch or inch and half. I managed to drive it home all the way in 3rd gear because it wouldn't let me shift out of the gear. I turned off the car in the garage and could smell burning clutch. Then started the car again and now it drives fine??? is there something I should be worried about and what happened? did my slave cylinder lose pressure or something?????
Old Jan 8, 2006 | 12:34 AM
ChaseSS's Avatar
nobody might have a clue?
edit: by the way it is a stock clutch
Old Jan 8, 2006 | 03:12 PM
wrencher's Avatar
wrencher
This is a common problem. You can try to flush the fluid to improve it some. But it is gonna need new clutch & hydraulic's to make it right. Search thru all the posts in here, tons on this one....
Old Jan 9, 2006 | 12:51 AM
yekta's Avatar
hahaha dude, u need to do drill mod. Put ur foot under the pedal and pull it back, feel will come back.You don't need to change anything. When u get time do the drill mod on your master cylinder, you'll be fine! U can find it on www.installuniversity.com
