Another T56 2nd gear problem
Old Jan 13, 2006 | 11:19 PM
GlennNo50's Avatar
Default Another T56 2nd gear problem
I have recently rebuilt my T56 due to 2nd gear popping out. I replaced the
1-2 shift fork all of the shift fork pads, the synchro keys and friction rings and hoops as well. Now the tranny wont go into 2nd gear or grind or anything. Every once and while I can massage it in while siitng at idle and it stays just fine. But it seems like the something is stopping it from going in. Any ideas as to what is wrong. Blocker ring or gear????????????
Old Jan 15, 2006 | 03:55 AM
GlennNo50's Avatar
Anyone have any ideas
Old Jan 15, 2006 | 09:54 AM
Farmer2's Avatar
When you had it apart, did the gear have any burrs on it from grinding gears prior? If so that could be the prob.
Old Jan 16, 2006 | 01:37 PM
GlennNo50's Avatar
The gear looked fine, after the first few times it started grinding I stopped using 2nd all together, so it didn'tget too much abuse. Coul dit be the ring that goes around the entire synchro assembly? The one that the shift fork moves.
Old Jan 18, 2006 | 06:16 PM
GlennNo50's Avatar
I took the tranny apart again today and found that one of the 2nd gear blocker rings that I just replaced was cracked. Hopefully that is what was causing the problem.
