Dead battery after shift light install?
Old Jan 16, 2006 | 01:19 PM
Jimmard's Avatar
Default Dead battery after shift light install?
So I installed my harlan shift light last night following the instructions I got off of installuniversity. I connected all the wires to the same ones that they did in their install. Went for a drive last night and everything worked great, great shift light btw. Well this morning I go out to start my car and I have a dead battery. I am wondering if this could be because I did something wrong? Bad ground maybe? or maybe its just the battery? My thought is that the wire i tapped into for my 12v source is not an accessory one that only has power when the ignition is on, but rather one that has power all the time. Although I did use the same wire that installuniversity did. Great way to start out my birthday .
James
Old Jan 17, 2006 | 09:24 PM
Murdock's Avatar
That was my first thought. Can you check it with a meter or test light to make sure it's only hot during acc or ignition?
Old Jan 17, 2006 | 10:49 PM
Jimmard's Avatar
I bought a new optima battery and everything seems to be working fine. I'll check the wire just to be sure, but I have not had any problems with the new battery yet so I am assuming all is well.
James
Old Jan 17, 2006 | 10:51 PM
Jimmard's Avatar
Also after jump starting the car and letting it run for about a half hour, I shut it off and it was completely dead. So I think the battery was the problem.
James
