Skip Shift
Old Jan 17, 2006 | 10:50 AM
Camaro_Guy's Avatar
Default Skip Shift
Is there any way to get rid of it? It's getting really annoying while driving around in the city.
Old Jan 17, 2006 | 10:53 AM
waiting2bl33d's Avatar
yes, there are many ways to get rid of the skip shift. you can simply put a resistor in-line that will get rid of it or they make a module that will also turn off the light they run about 20 bucks.
Old Jan 17, 2006 | 11:15 AM
2_wacko's Avatar
http://www.lmperformance.com/2512/1.html
Old Jan 17, 2006 | 03:35 PM
SLP4CamaroSS's Avatar
u can by a resistro i cant rember look it up
Old Jan 18, 2006 | 01:44 AM
MdFormula350's Avatar
I would get it edited out of the computer only cost me 20 bucks at my local shop.
Old Jan 18, 2006 | 01:50 AM
CRAGER's Avatar
Administrator
Go to Radioshack and buy the 2.2K Ω (2200 Ω ), 1/2 watt resistor* ($.99)
Here is a link to show you how to install it:
http://www.installuniversity.com/ins...adio_shack.htm
Very very very easy to do.
Peace,
Craig.
Old Jan 18, 2006 | 02:23 AM
LookinAtMyPlate's Avatar
my skip **** doesnt even ever come on it seems like it did alot when i 1st got my car but i think i got used to it and now it doesnt affect me at all somtimes when it does comeon i acctualy use it
Old Jan 18, 2006 | 04:55 AM
SIC LSX's Avatar
or find someone that can tune it out
Old Jan 18, 2006 | 05:04 AM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
I want to put mine in again to see if I can have my gas mileage back!
Old Jan 18, 2006 | 07:23 AM
2000 TAWS6's Avatar
I doubt that it will help with your mpg, as a matter of fact, since I disabled mine, I notice that I am shifting at a better rpm than when the CAGS worked.
I find quite often I am shifting from 1 - 2 when the CAGS light is on.
I'd look into other areas to improve your mpg, plugs, air filter, tire pressure, and O2 sensors.
Old Jan 19, 2006 | 03:00 PM
sscamaroburn02's Avatar
you can buy the resistor or go to slp and buy the plug n play module. This costs $25
Old Jan 22, 2006 | 06:52 PM
bobodog's Avatar
also you can just shift at 2500 rpm or higher all the time. thats what i do. i kinda like hearing my motor juice up.
Old Jan 24, 2006 | 08:04 PM
mbraun's Avatar
If I remember correctly you need to use a 2.2 ohm resisotor across the line going to the tranny. this simulates the the coil resistance of the soleniod that engages when the skip shift is activated. This then lies to the computer and you do not get a check engine light. the other option that I like and use all the time is for street driving just go from first to third. This is not so much of a step that the rpm does not fall so far and the car seems to like it fine. best of luck
