clutch slipping?
now for the second question... what type of clutch should i get? i'm a little tight on money right now, so i can't go overboard... also would it be advisable to change the flywheel too? if so, which is the suggested brand for the job?
thanks
Truth be told it can be anything... my car is having a throwout bearing problem (i think) cuz it grinds almost every time i go into 2nd gear and occasionaly 1st and 3rd... I'm hoping swapping everything out will resolve this....
A slipping clutch means that when the car is in gear and under acceleration (usually when you're getting on it pretty good) the clutch is slipping against the flywheel and pressure plate. You'll see this as RPM jumping up under acceleration without you touching the clutch.
