How Much Fluid
Old Jan 31, 2006 | 08:39 PM
mrhzk35404's Avatar
Default How Much Fluid
Goes in a T-56?
Old Jan 31, 2006 | 09:10 PM
DEE99TA's Avatar
The spec is 3.8qts dry. So 4qts should do it.
Old Jan 31, 2006 | 09:14 PM
mrhzk35404's Avatar
Thank you very much.
Old Feb 1, 2006 | 03:37 AM
lucky's Avatar
Fill till oil runs from the fill port replace the plug,remove the reverse light switch and add another 1/2 litre.
Ciao
Old Feb 1, 2006 | 06:47 AM
calhoon's Avatar
Unless you are filling a GTO, that is un lucky advise.
