i need a clutch.....help me choose
my clutch just went out and i need a new one bad.i was thinking about getting a spec but i read alot of posts saying they suck or they go out in a few months.i do hear good things about the textralia clutch.so i thought about that one.i also hear about the ls2/ls7 combo.will the ls combo work with a lt1 or is it strickly fo ls cars?please give me some i deas on these 3 clutches.and if you have any one of these 3 what are pros and cons of them.
oh my car is only driven on the weekends, but i hit traffic still
aluminum or steel flywheel for daily driver?(mild dragging also)
thanx all 4 ur help
thanx all 4 ur help
LS1 clutches will not work at all with an LT1 motor. Different cat altogether. Aside from the bolt pattern on the crank, the LT1 requires a "pull" style special linkage (LS1 and regular small block chevy's are "push" style).
Based on your mods, I'd consider the LT4 clutch setup. Would still be smooth as a factory clutch, but is 'better' than a stock LT1 clutch.
I had a SPEC 1 in my LT1 car when they first came out and loved it. Great clutch and I would recomend it.
