Problems, noises, and grinds, oh my!
However I now notice that if you change into second quickly, youll get a slight grinding noise... its more noticeable audibly then actually being able to feel it. Itll do the same into the other gears, but second is by far the worst. The other gears make no noise that I can tell, but you can still feel a vibration you have to push passed to engage the gear. If you let the revs drop all the way down however, there is little to no noise or vibes. Feels very similar to my brothers car with a damaged syncro in 2nd gear. But this is sounding more like a clutch issue? Ive tried double-clutching and that doesnt really alleviate the problem.
So far ive only had the chance to check the tranny fluid which is full and clean, and the hydraulic reservoir is full also and clean. Where else to start looking? Is this sounding more like a clutch issue? Would bleeding the system be worth the time? Pilot bearing? Any help would be great appreciated!
The clutch was replaced about 20K miles ago with a stock Z06 unit, along with the master/slave. The car has 78,000 miles in total.
